Best way to export to Daz from Blender?
If I have an environment I made in Blender that I'd like to export for use in Daz, what is the best way to do that? I hear .obj don't work correctly.
  • mikael-aronssonmikael-aronsson Posts: 607
    edited September 2017
    .obj should work fine, both Blender and DS work fine with OBJ, dont go after what you "hear", try and see for yourself if it works ok, only take a minute to test.
    With that said OBJ works fine with geometry but you may run into problems with materials/surfaces, some tweaking may be needed but you will have the same problem with other applications.
    Post edited by mikael-aronsson on
  • nicsttnicstt Posts: 11,715
    If it is at the correct scale in Blender, be sure to import it as 10000 not 100%
