Render bar
Hi everyone....i have question for you....what does it metter it the render bar fills up? I did render but the bar did'nt ever fill 100% .... there are parameters to modify? Thanks
In Iray theer are three things that can cause the render to stop:
I suspect your render is running out of time before it is converged, and so stopping before the bar has reached 100%. If that is the case you need to adjust the values in Render Settings>Editor tab>Progressive Rendering (or give the scene more light so it converges mor quickly, adjusting the appearance using the Tone Mapping options).
