Library directory
Mescalino
Hello,
I have two directories that contain Daz3d Content:
\Users\Public\Documents\My DAZ 3D Library
\Users\NAME\Documents\DAZ 3D\Studio\My Library
Sometimes its hard to find something as i go trough some clothing i have to look at sevral places. Is it possible to merge these two directories? (or is there some logic behind this?)
If so do i copy paste 1 directory into the other (and what would be the the main one then) or is there a way to tell DAZ that he shoul look in both directories but display only 1.
Post edited by Mescalino on
The "My Library" is intended for the files you create. You can merge them, just move all files and folders under "My Library" to under "My DAZ 3D Library".
You can merge them, but they are separate to avoid confusion/conmflict between the daz Install Manager (My Daz 3d Library) and user-created files (My Library). You may also have a My Daz Connect Data folder, used by Daz Connect for its installs.
Ah ok so the IM**** zipfiles are placed in the my daz3d library folder and stuff i get from renderosity and such in my library. Guess i will leave them split for now then to avoid confusion.
One thing to bear in mind - if you have ExP products (morph sets) for Victoria 4, Michael 4, Kids 4, or the SubDragon those do have to go in the same content directory as the base figure (but non-ExP addons, which would be most clothes and hair and many characters, you can place anywhere).
