HDRI LIGHT
in The Commons
Does anyone know of an HDRI with backdrop that does not only have light from above, as in around midday?
I am looking for an evening light angle.
Grateful for suggestions.
I have a low sun HDR here (it's the first one).
Thank you, most helpful. I assume that I must add my own backdrop or whatever.
If you are rendering with Iray you just need to set the render option to Draw Dome and it will draw the HDR in relation to the scene. However this is just a skydome so you would need your own ground.
You can also show the HDR in 3Delight somehow but I forget because it's been a long time since I've used the program.
Thank you.
I use Iray, I have set to draw dome.
I can add a garden or whatever.
