Fitting V4 Skeleton to Genesis 3
Hello Everyone,
As you probably know, there is no skeleton figure for Genesis 3 so I'm trying to make the Victoria 4 Skeleton (https://www.daz3d.com/v4-skeleton) fit to it unless there is a better option. I was wondering if there was a way to make the Victoria 4 Skeleton fit to Gensis 3 without warping the skeleton. I've tried using the autofit feature and selection Victoria 4 as the original figure, but the skeleton ends up getting warped. Does anyone have any recommendations on how to do this?
Could you go the other way and fit G3 to the Skeleton?
You might try fitting the skeleton to a Genesis 2 Figure first, save it, then fit it to Genesis 3.
I tried that and got a very strange result, the G3 figure's arms pointed upward in a V shape and the body became distorted. Unfortunately it didn't work out too well.
I fit the skeleton to Genesis 2 and the result is basically the same as fitting the skeleton to Genesis 3. The warping of the skeleton happens in the same areas.
