default poses - what am I missing?
I purchased Romi fofr G3F and see it comes with 18 poses fto match the G3 defulat poses.  I am only aware of one default pose.  Are there others?
  • There are, as I recall, several poses in /People/Genesis 3 Female/Poses
  • Hmm .. not there.. I have about a dozen pose sets and don't see anything appropraite.  I manually manage my files.  Maybe only on connect?
  • No, they are part of the Genesis 3 Female Starter Essentials package. They may not be the psoes intended, since there are more than nine, but I would think the default poses would be those included with the base package.
  • MelanieLMelanieL Posts: 7,867
    edited September 2017
    G3F Starter Essentials should include 18 poses named "Fashion Model Pose nn" - the Blouse, Underskirt, Skirt and Shawl each have a set of 18 matching poses under "Actor - Fashion Model Poses" in the parameters tab.
    If you have installed the G3F Starter Essentials correctly, you should find the 18 poses in Content Library under "People - Genesis 3 Female - Poses" (unless you deliberately copied them somewhere else).
    ETA: I use DIM not Connect, so they are in the .zip DIM uses, which I believe should match the one in your Product Library.
    Post edited by MelanieL on
  • 3Diva3Diva Posts: 12,058
    They are these:
    Look for the bright pink/fuchsia figures in your Smart Content >> Poses tab.
  • Thank  you all - I have them.  I just didn't realize they were called fashion model poses
