apply shader
hi. I created a graft prop for Genesis 8 . but the Shader of my prop is different from the Shader of Genesis 8. please tell me how to assign the human Shader for my props to be exact match.
  • Richard HaseltineRichard Haseltine Posts: 111,430
    edited September 2017
    Apply the correct shader to your graft (probably the iray Uber Base - you can see by selecting a surface on Genesis 8 and looking at top-left of the Editor tab of the Surfaces pane), then with a single surface of Genesis 8 selected got to Edit>Copy>Copy Selected Surface(s), then select teh surface(s) of your graft and go to Edit>Paste>Paste To Selected Surface(s). If necessary change the maps, but the settings should match.
    Alternatively, if this is something you are going to do a lot, select Genesis 8 and a suitable surface on Genesis 8, File>Save as>Shader Preset, then select you graft and all its surfaces and apply the saved preset.
  • SimonJMSimonJM Posts: 6,100
    Does the copy/paste now take across shader, I am sure it never used to.
