Assign new diffuse map using IDE Script
Hello!
I would like to assign a new map / image file to a certain Surface.
I would really like to do this by Script.
However, I'm lost on how to that, and I didn't find any example for this.
There's no "Record" button for a macro like in Microsoft Word where one can inspect the recorded macro, is there?
Thank you very much!
It would be helpful if you could tell us something of the specific item you are working on. If this is purely a generic question, the answer depends on the latter. However, assuming that you are referring to typical, more recent DAZ content, that content is usually loaded using a .duf (DSON) file, which tells DAZ Studio what to load and any settings that accompany the item. The .duf files are merely compressed text files and be open and viewed in a text editor after uncompressing them using a utility such as 7zip, etc. So, if you can find your way through the script conventions used, you could/should be able to find the image file reference and change it, perhaps saving the result with a different filename in order to preserve the original.
BTW, another option is to simply open the item in DAZ Studio, change the image maps in the Surfaces tab along with any other settings that you wish, and save it as a Material(s) preset.
Thank you!
You'll need something just like this:
