Reset multiple morphs?
After searching on the forums I found out that I can click Alt+Right Click to reset animated morphs which is very helpful!
But it would be even quicker work flow if there is a magical shortkey to reset multiple morphs/parameters ?
Thanks ahead! :)
I don't know any shortkey to reset multiple parameters. I usually use "Alt" and click, click, click....
But...
In the "Edit - Figure" menu can zero or restore (to memorized) all poses or shapes.
Shapes are usually kind of morphs like Bodybuilder or Victoria8 and poses are of course all joint rotations etc..
If you want to reset only some parameters you can go to Edit Mode in the parameters tab (Right Click - Edit Mode).
Than choose the parameter you want to reset by holding ctrl (single) or shift (block) (same as Windows standard) and click on them.
Now rightclick and choose "Set - Values".
Unfortunately this will also set set "Default Value" of the parameter!
So make shure you don't choose a parameter that have a different default value than "0".
Of course this is not faster than "Alt" Click them. ;-)
But if you have always the same set you want to reset, you can mark them as your Favorites (the little heart icon at the top right of the sliders).
Than you can shift select them all in the Favorites and set the values this way.
It doesn't work if you i.e. select a "Point at" parameter and "rotate" paremter together. Then the "Set Value" will be greyed out.
Kind regards, Eagle99
