M4 texture to Genesis
jaebeajaebea Posts: 456
I'm starting to play with Genesis more now. Creating one of my M4 characters but having trouble with the texture for some reason. Maybe I am forgetting a step? I go into the surfaces tab and choose M4 in the UV Set. At this point, I should be able to apply the texture but its not fitting. I tried several M4 textures but none of them fit. The V4 textures fit. I searched the forum for this but maybe I didn't use the correct key words.
  • fixmypcmikefixmypcmike Posts: 19,738
    Apply the mats, then make sure you have all the surfaces selected when you choose the UV set
  • jaebeajaebea Posts: 456
    That was so weird. I had changed the UV to M4 but when I applied the texture, it had all popped back to v4. I changed it again and the texture fit. Thanks!!
  • BejaymacBejaymac Posts: 2,014
    That's normal, Poser material presets don't have any UV settings in them, and the older DS native formats usually only had "default" listed in them, so whenever you apply one of these to Genesis it resets the UV's to the default, which is V4.
