Create Utility script
Hello,
Can you explain me how to make a utility on Content Library ?
For example, I would like only modify cutout opacity on a prop' surface without touch anything else. For that I want to create a .duf file with .png preview wich make that on a simple click.
For other example I would like to modify cutout opacity AND normal map together without anything else with a .duf.
I hope it's clear because my english.
Thank you so much !!
Ok I found by myself :)
Just save as shader and select !
Hi, you said you found out how. can you share that information with me? I'm also in need of how to create a simple script to change a meterial setting just with one click.
any help is greatly apriciated.
Thanks. :)
Hello;
I had already say how i did :Just save as shader and select
It was my first try on DAZ. Maybe it's not your question
