How to convert pz2 to aniblock?
ruekakaruekaka Posts: 348
Hi everybody!
I started to play a bit with animations and could not figure out how to convert a animation stored in a pz2 format to an aniblock.
I use one of the SKA animations. If I drag and drop it to a V4 it works as expected.
But if I drag and drop it into a cell of the animate2 timeline I got funny stuff. The animation does not look like a walk cycle. V4 flaps with her arms and the legs doing strange moves.
Should that normally work and I'm just doing something wrong?
The goal is to combine the pz2 moves with an aniblock.
I found the converter from aniBlock to Poser in the shop, but not the other way around.
Any hint is welcome!
  • JaderailJaderail Posts: 0
    edited March 2013
    Put the pz2 animation on your V4. In the Menus pick Window>Panes(Tabs)>Timeline. Test the animation, then run it to the the 0 frame. Now open Animate and Right click any part with out a setting. You will get a drop down Menu. Select Create AniBlock from Studio Timeline. You will need to Name it and Save it to your Aniblock folder in DS.
    Post edited by Jaderail on
  • ruekakaruekaka Posts: 348
    Perfect, thanks!
  • javamanojavamano Posts: 7
    Does not work in 4.9.1.30 Pro
  • Richard HaseltineRichard Haseltine Posts: 111,363
    Did you buy a full AniMate 2 license? If not AniMate 2 switches to Lite mode after thirty days and the feature used above is not available there, as I recall.
