Trying to Give V7 Pale Skin
Which shader setting(s) do I need to adjust to give V7 pale skin?  Her default mats don't look right when I make her a redhead.
«1
  • nonesuch00nonesuch00 Posts: 18,878
    It's easiest to just use an V4 texture plus V4 to G3F templates from somewhere if you have BlackSmith3D's Texture Transformer or their BlackSmith3D Pro program. Sorry I don't know if the standard version can do the texture remapping from V4 to GF3. Those are at Rendo. At Rendo there are some good ones going by the name of London, Dublin, and such. There are also some at DAZ. After conversion you still need to convert them to iRay and apply shader setting from another human iRay product to the Surfaces or makeup you own using the guide from AndyS (moniker in these forums) at his DeviantArt site (based on the DAZ Forum thread Comons - Fiddling with iRay Settings - a lot of good collective work AndyS collated on his DeviantArt site from that thread).
    If you want to make the V7 skin appear pale as you can without editing textures just surfaces choose white for the translucency color and dial down the strength of the translencency color channel to 0.05 or 0.01. If you make it 0.0 then that means no translucency at all and you should get a render that is the color of the diffuse map before rendering. So if you like the color of a diffuse map and want that then dial down the translucency color to 0.0 for the most part.
    Then make the glossy reflectivity about 0.6 and the Glossy Roughness about 0.8.  Lower varlue will make look oily to sweatly on those so play with them as appropriate for the scene.
    Finally if you have the Painter's Lights (j. cade) or BOSS Lights (The Pholosopher) or similar bought from the DAZ 3D Store that will take you the rest of the way although
    I don't know how far you can push V7's skin from the diffuse base but looking at the diffuse base map it looks to be pale enough for most purposes.
  • 3Diva3Diva Posts: 12,058
    edited August 2017
     You can try my custom shader (attached). It's my favorite shader. I hope you like it! :)
    Just drop the attached files in your My Library >> Presets >> Materials folder.
    duf
    duf
    V7 - Paler.duf
    146K
    91 x 91 - 15K
    Post edited by 3Diva on
  • kyoto kidkyoto kid Posts: 42,461
    ..if you want to make your own custom skins, Skin Builder Pro 3 is an excellent tool.  You can even give your characters freckes, age spots, moles, custom brows, lashes and vascularity with it..   I've created the perfect freckled skin for my ginger haired Leela as well as a very accurate albino skin for my namesake, KK.
  • fastbike1fastbike1 Posts: 4,084
    Before you do anything else, try changing Translucency Weight to 0.15.
    Try the simplest thing before anything else. You can try tints later.
    Here's V7 "out of the box" on the left, on the right is her with my shader applied.
    VERY... NICE...  hella good timing, too.  I just bought a copy 65% off.
    Thanks!
  • There's always Photoshop or GIMP, too. It's pretty easy to lighten a skin and desaturate a little to make convincingly pale options.
    @divamakeup
    Sadly, every time I try your shaders or see an example, they have a greenish- gray tint. This is on two calibrated monitors that are also used for photo processing,
    fastbike1 said:
    @divamakeup
    Ah thanks for the heads up. I was wondering why when I try to share my shaders people just complately ignore me. Not nice to go out of your way to try and help people and then just get ignored. I guess if the shaders look like crap to others, then I guess that's why... lol The shaders look good on my monitor, but I probably need to calibrate my monitor. I haven't done a color calibration in ages.
    Thanks for the heads up. I guess I know now why I always get ignored. lol
  • Ah thanks for the heads up. I was wondering why when I try to share my shaders people just complately ignore me.
    Sorry... for the record, they look slightly greenish-grey to me, too.
  • They look pretty good to me, just on the less red end.
    I can use Skin Builder to learn how to create my own skins, but for my immediate needs, this worked perfectly.  Thanks!
    ...my workstation still needs to be set up in my new place otherwise I'd post sone examples of what I've done with it.
    What about now? Is it still greenish-grey?
  • barbultbarbult Posts: 27,619
    That is much better.
    Good deal. Thanks, barbult. :)
    Attached is the updated shader, if anyone is interested. If not, oh well, at least I tried. lol
    duf
    duf
    V7 - Paler 2.duf
    137K
    Just a clarification - that file is not a shader; it is a material preset.
    edited August 2017
    Oh sorry, yes, you're right. One can use it as a shader though as if you hold down control and double click it you can tell it to "ignore images" and apply the settings to any G3 or G8 character. :)
    edited August 2017
    fastbike1 said:
    @divamakeup
    Don't let it bother you ;). It'll happen a lot. Most ppl will download and say nothing, a small percentage (usually the same people all the time...lol) will say thanks. Just give it away and not require or expect a thank you or for acknowledgement and you'll be a much happier person :P
    Laurie
    Post edited by AllenArt on
    AllenArt said:
    fastbike1 said:
    @divamakeup
    Laurie
    Just would be nice to know if your time and engery is appreciated. If it's not and no one likes what I share then I am only wasting everyone's time, my own included. :) lol It's not that I want or need a pat on the back or kudos, I share because I want to share and try and help because I enjoy helping. However if what I'm doing isn't helping anyone then it stands to reason that I guess I shouldn't waste people's time. :) I'm not saying that to be mean or rude or anything, and I hope no one takes it that way. I just don't want to waste anyone's time. :) I know what I like and I know what I, personally, think looks cool. However I've long known that I'm odd. lol
    ...one nice feature of SBP3 is you can use the overlays on any skin so if you want to give your red haired character frecles, you can.
    AllenArt said:
    fastbike1 said:
    @divamakeup
    Laurie
    ...yeah, display calibration can be a pain. I have two displays each by a different manufacturer and it took a lot of effort to get them to match as the neutral setting on one was "cooler" in light temperature than the other
    AllenArt said:
    fastbike1 said:
    @divamakeup
    Laurie
    Oh, I generally try to remember to thank soon as I download although I don't always remember too. I generally don't remember to post a render using or even get around to using most freebies or bought products for that matter and when I consider I CPU render it's a wonder I get hardly any progress, which I don't. At least not nearly as quick as would be possible with a nVidia GPU to quicken the learning curve with regards to rendering.
  • Chanteur-de-VentChanteur-de-Vent Posts: 567
    edited August 2017
    This. I usually set the Translucency Color and Transmitted Color (all the way to the bottom) to white. See comparison render for result. You can produce a lot of different skin tones from normal to pale by changing the Translucency Color between white and the one that comes with V7.
    1280 x 1024 - 292K
    2000 x 2000 - 3M
    Post edited by Chanteur-de-Vent on
  • VyusurVyusur Posts: 2,235
    edited August 2017
    V7 walking in the garden, pale enough.
    900 x 1200 - 2M
    Post edited by Vyusur on
    @divamakeup "What about now? Is it still greenish-grey? "
    Much better. Just looks on the pale ("Nordic") end to me. Which I take to be intentional.
    Good deal. I'm glad it looks better. Thanks! :) He did ask for pale skin. lol
  • StormlyghtStormlyght Posts: 666
    Thank you @divamakeup!
    No issues or argument from me. Just letting you know what I see given I mentioned tint before. Skin looks pretty natural, just someone with naturally fair complexion that doesn't go out without some sun protection.
    You're welcome! :) I hope it's helpful!
