saving multiple morphing obj into one morphing prop?
DisparateDreamer
I have three morphing obj that I made that I am trying to combine into a single morphing prop.
I can't use the obj to pp2 script, it only works on a single obj.
Anyone know how to do this?
you need to load the base object, then save it as a Figure/Prop asset. Then open that object and goto Edit/Object/Morph Loader Pro and load each morph obj, and once those are done, save as/support asset/morph asset and save all the morphs.
that will only work in DS correct?
Basically what I'm doing is export all three obj together at default (morphs at 0) into a new melded obj
dial one morph to 100, export as new obj.
zero morph again. Dial next morph to 100 and export all again.
repeat for all morphs in all three obj.
load new base mesh, import all new morph obj...
save as new pp2
pretty much the same, but sadly incredibly time consuming, has taken all day :(
was hoping there was a way to save it w ithout the extra work. I already had loaded the morphs separately into each obj.... sigh.
Um... couldn't you just make the Base single object. Then add all three morphs and Save as pz2?
the three thigns are not morphs, as i said. Each of the three items had several unique morphs. And the 3 things aren't the same and can't be loaded into the other.
I miss understood, the part about three morphing object and needing one object file for it seemed to say three objects with one morph each.
