Is there exists any way to make work Outfits and Hairs on Cookie! (LadyLittleFox's character) ?
Thanks, so, I want use cute Cookie! character in a further project dedicated to manga/toon work!
I want know if any of you know a way/addon/product that can making working HAIRS or OUTFITS (shoes/clothes/well some of its), and why not Genesis Skins (but I strongly doubt of it) ?
Applicable models possible will be:
- Clothes/Outfits/Shoes/Hairs (Skins?) originally for Genesis 1 Female
- Clothes/Outfits/Shoes/Hairs (Skins?) originally for Genesis 2 Female
- Clothes/Outfits/Shoes/Hairs (Skins?) originally for Genesis 3 Female
- Clothes/Outfits/Shoes/Hairs (Skins?) originally for Genesis 8 Female
Thanks for any of your answers, greatly appreciated!
Have a nice day friends !
    edited August 2017
    AFAIK Cookie is a standalone figure.   Crossdresser could be used to convert clothing. She has her own wardrobe of clothing, and also there is quite an amount of free clothing for her.
    https://www.daz3d.com/forums/discussion/24271/
    you can find CrossDresser here   http://www.evilinnocence.com/shop/
    Post edited by Chohole on
  • LlynaraLlynara Posts: 4,772
    edited August 2017
    You can use just about any hair on any figure. Here's how:
    1. Instead of autofitting, just load Cookie, and then the hair in the default position.
    2. Use the X,Y and Z sliders in the parameters to get the hair where you want it. Her head is really big, so you'll need to scale it up.
    3. When you have the hair the way you want it, parent the hair to the head so it will follow the figure when posing.
    As far as getting clothes on Cookie, here are a few options that work well:
    • Use dynamic clothing. Most clothing will drape just fine on most figures.
    • Use VWD (Virtual World Dynamics at Rendo) to convert and drape ANY clothing into dynamic and drape it through that program.
    • Use CrossDresser to convert clothing to fit Cookie. There are instructions on their site to convert Genesis props to other figures. I haven't tried that yet. You can also use Sickleyield's converters here at DAZ to convert clothing backwards to Genesis, then use Cross Dresser to get them onto Cookie. Note: You'll need a CrossDresser license to convert things to Cookie. (I don't have one or I'd do a test run for you.)
    • Someone has a thread around here called "How to Convert Clothes to Any Figure" but I can't find it at the moment. I'll post here as soon as I do.
    Note: Since Cookie is small, you may have to scale her or the clothing to get it to fit right.
    Here's a quickie test render. It's awful, but at least it shows that you can get the hair and clothes on her. I scaled up Krayon Hair to nearly 300%. This is the Arthurian Dress from the Nineve 6 Pro Bundle. I scaled it using the X scale and Y scale, then draped with VWD. It needs more work on the sleeves. None of the textures are designed for Iray, but can be tweaked.
    1500 x 1433 - 1M
    Post edited by Llynara on
  • AtanaciusAtanacius Posts: 340
    edited August 2017
    Thanks a lot FOR that answer, will experiment that then!
    Thanks also for your try !
    Post edited by Atanacius on
