Where are keyframes on the timeline?
djfilms_d40a8287d1djfilms_d40a8287d1 Posts: 12
I'm new to DS, trying to get away from Poser. But...
I have a Poser animation of the Mil cat, with tiger textures. I import to DAZ Studio 4, and I want to delete keyframes from one leg. I can't see how to display the keyframes on the timeline, so I can examine then delete appropriate ones.
Any advice gratefully received.
  • Richard HaseltineRichard Haseltine Posts: 111,788
    One way that should work is to select the leg bones, then use the Next/Previous keyframe buttons on the Timeline to go to each keyframe in turn and use the Delete button to remove it. You may need to enable advanced controls from the pane's menu (right-click on tab or click the menu button in the corner). However, it has t be said that the DS Timeline is very basic.
  • djfilms_d40a8287d1djfilms_d40a8287d1 Posts: 12
    Richard,
    Thanks for your reply. The "advanced" view is anything but! I don't see a delete button anywhere.
    Maybe I'll just stick with Poser.
    regards
    The delete button is the key with an x on the end, last but one button on the right.
    Thank you, Riichard!
