Anyone else having this problem with G8F clothing?
AllenArtAllenArt Posts: 7,175
edited August 2017 in The Commons
See the weird "flapjacks" on the front of the jacket over her breasts? I get it with this cloth item, I get it with a couple items in OOT's Mega Wardrobe for G8F - mostly just the loose clothing and not so much the tight stuff. Is there a way to fix this other than smoothing? Cause I have the jacket at 25 smoothing and it still gets those weird flapjacks. I don't want to (meaning SHOULDN'T HAVE TO) deal with this with every piece of looser G8F clothing. Nothing I can think of in the Genesis 3 line did this. It happens with nearly any morph I use too - this just happens to be 50/50 V8 and Bethany 7. Happens with 100% Genesis 8 female line too.
Any way to fix before I start putting in tickets? Need help :) Thanks.
Laurie
927 x 1200 - 207K
Post edited by AllenArt on
  • Zev0Zev0 Posts: 7,123
    edited August 2017
    That cannot be fixed unless the clothing has dedicated fbm shape support. Only other way is via Fit Control, but that isn't released yetcheeky
    Post edited by Zev0 on
    edited August 2017
    Well, it's on my invisible wishlist. LOL I'll try and be patient....hehe. I WILL say tho that I think it's pretty rotten that clothing made FOR G8F doesn't really fit G8F completely without having to buy something else in addition to the figure. Didn't HAVE to buy fits with G3F unless you were using clothing from an earlier generation of figures /rant.
    Laurie
    edited August 2017
    @AllenArt
    Laurie, I'm not seeing this, at least with Mega Wardrobe. First render is with Kamryn G8F from Silver, second is straight G8F.
    The issue seems only to affect some models with some cloths. At first i though it happened with models with large than average breasts, but the third render is BJ Lyra. Note that this outfit was fine on G3F. Fourth render is BJ Lyra
    So I'm out of ideas, I only have a few G8F outfits that are loose. I'm not so sure it's the clothing. I can see the issue on certain characters with the Mega Wardrobe and the Lingerie Robe set, but these outfits work fine on other characters.
    500 x 750 - 332K
    500 x 750 - 333K
    500 x 750 - 509K
    500 x 750 - 479K
    Post edited by fastbike1 on
    edited August 2017
    I'm not sure what's causing it either. Wish I knew. If it's a breast problem, I tend to dial the breasts down on my female characters, so maybe that's a hint. Isn't Lyra a bit on the smaller breasted side? I'm rendering her now in that exact same sweater and I'm getting the "flapjacks" ;). Had to crank the smoothing. **sigh**
    Laurie
  • WilmapWilmap Posts: 2,917
    I've made clothing for g8f which has that problem and the only way I could find to help was smoothing out the weight maps under the bust area.
    I hear you. It was really bad on Olympia 8 and GDN Sarah, both pretty busty. However Lyra shoed it as you can see, and she is rather more "normal". Kamryn is fairly "healthy" but doesn't show issues. I tried a number of iterations and couldn't come to a specific repeatable cause. You will note that even the promo renders for the jackert in your OP show the same issue as you highlighted. On the other hand, I could not provoke this issue on any top that was more form fitting and gave up after ~20 renders w/ various tops/characters.
    Laurie
