DAZ 4.5 pro - how do I use Dynamic clothing
Dalek
I've looked all over the internet and I can't find a good, clear step-by-step instruction on how to use the dynamic clothing in DAZ 4.5 Pro.
I read one, tried to follow it and it made no sense - I click on the clothing in DS, tell it to drape, and it says I haven't selected anything, when I have.
So please, can someone offer either a good clear tutorial (not animation, just a single pose) on how to do it?
Ta muchly.
Here is some info that might help http://www.daz3d.com/forums/discussion/15554/#228264
But I did forget one crucial aspect, to set up what the clothing has to Collide with.
Are you using Genesis ot Gen4 as the process is different for them both.
I'm trying to drape a superhero cape onto M4.
It won't let me select the item to drape, the cloth it will affect or even what to collide to. It's as if the controls are all there, but they won't work.
this one http://www.daz3d.com/dynamic-cape ? I don't have this so I can't check to process.
Do you have the Dynamic Clothing Control or just the basic one that comes with Daz Studio.
Anyways
Select M4 load Cape
Open Timeline (Windows > Panes (Tabs) > Timeline
Frame one: Standard M4 T-Posed with Cape loaded. Cape should have Fit To set to M4 in the Parameters Pane
Frame 20: Pose M4 and dial up any body morphs for M4 at this stage.
Open Dynamic clothing Pane
Select the Cape
Set Drape to Animation
Set Collide Parameters - Self explanatory.
Hit Drape
Either Stop the Drape at Frame 20 or you could use the last ten frame as a static drape type of thing if needed so let it go all the way to frame 30..
Hi Pete
The cape is from a Renderosity freebie set and is a prop. I can't select it from the Dynamic Clothing tab... I can't select ANYTHING in the tab.
It's the basic DC plug-in which came with the software.
Dynamic clothing for Daz Studio isn't the same as Dynamic clothing for Poser. Sorry to inform you that only Optiex based Dynamic clothing will work in Daz Studio.
There are quite a few DAZ Studio dynamic freebies at Martin's site. http://www.optitex-dynamiccloth.com/FreebieDownload01.php
Thanks Khory..doh why didn't I think of that. facepalm in shame.
Not the cause of the problem in this case, but FYI — clicking on Optitex dynamic stuff in the Viewport doesn't select it. The only way to select dynamics is by clicking on the root of the object (not any of the parts) in the Scene tab. I think it's something to do with how the dynamic material is constructed, it's not quite a standard mesh object.
