Urban Sprawl 3 Road Texture/surface
I am sure I am missing something painfully easy, but I can't get the street texture to show up properly.
The asphalt appears to be applied in the wrong scale. See screenshot of US3Block01 Iray, this is how it looks when first loaded, no changes made:
Applying the US3 Multi Layer Road Surface does not change anything either.
Apart from the scale of the texture, how do I get the white street lines to appear? I understand the road texture has 3 layers, but experimenting with the layer 1-3 weights does nothing to how the texture looks.
Any help would be appreciated!
If the road surface is not scaling correctly, is may be that the white lines are scaled to match the road surface.
https://www.daz3d.com/forums/profile/31795/Stonemason Here is (his/her) forum profile if you want to direct message about your issue
https://www.daz3d.com/forums/discussion/86536/urban-sprawl-3-it-s-here-in-the-store-no-really-go-see-commercial/p1 And here is a link to the forum board for this item, maybe there is a fix for your issue on there.
Thank you, James for pointing me in the right direction.
you need to render the image to see that road shader properly,
