No Shadows when rendering In Iray Interactive
Hello everyone,
I've been searching on the forum if anyone had this problem too but I didn't find anything.
Well, I've been trying to render a sequence with Iray, not in "Photorealism" but in Interactive as I wanted some object not to cast shadows. So I did what I wanted and deactivated "cast shadow" on the object and verified that it was still active on everything else and it was. Before rendering, I made sure that "shadows" in the render setting was "on".
Unfortunatly, despite all my effort, There is absolutly not a single shadow in the render and I don't understand why. I've been using DAZ 3D since a week now so probaly it's due to my lack of knowledge but I'd be glad if anyone could help me with this one as I'm getting truly desperate ^^'.
Anyway, thanks in advance to anyone who could help me.
What lights are you using?
I'm using Spotlights and Point Lights and there are no shadow rendered for neither of them.
Select the lights and make sure that Shadow Type, under the Light group in the Parameters pane or in the Lighting pane, is set to Ray Traced. By default it will be set to None.
Yes!!!!! This is it, thank you so much my friend ;)
