Instal Manager reset the download & Instal locations
Hi
I updated the instal manager and found later that it had wiped my download & Instal locations so now almost a thousand items are in a different locations .
As the new default (C:) is an SSD I need to move everything to my larger HD drive but Install manager doesnt see my old content any more.
Has anyone run into this issue?
How can I combine these into one drive so that Install manager can recognise both groups of downloads?
I take it there must be some record file(s) that take care of this?
Thanks for any advise;)
Installing a new version should not change settings, unless you also set up a new Daz account or used a new account on the computer (the DIM settings are stored in the user's AppData or Mac-equivalent folder). The locations of the installed content are kept in the individual .dsx files in the Manifests folder (alongside the Downloads folder by default): if you can't see previous isntalls that is presumably missing (and that suggests some serious issues as the default location is in the Public Documents folder, which would not be affected by either of my thoughs on the root of the problem).
I did change my login as I have a new ISP it sounds as if that was it though its still the same acount?
As for the files, the downloads are there but in two different locations.
I have uninstalled so only the post change downloads are listed.
Objective: I want to move the new downloads to the origional disk and re-install?
I hope this makes sense;)
You mean the zips? Those you can just place in the new Downloads folder and they will work.
No, I dont want to move them to the new folder thats an SSD (C:) and is too small.
I need to move them to the old folder (D: larger drive) but will the install manager see them?
Currently it is not seeing the old downloads only the new location.
Ah, so (again, assuming this is the isntall zips we are talking about) move them to the old folder, then in DIM click the gear icon to open preferences and in the Downloads tab set the folder to the location you want to use.
I have moved the new files and have have the location reset to the old folder but the old content still does not show in the install manager.
Damn, rechecked the downloads settings and its reset to C: drive again????
Will continoue to headbut the DIM until it complies.
Okay the ready to install colum looks okay now.
I think I'm gonna have to be paranoid and check the setting on the DIM before I do any downloads or installs from now on.
Correction, I'm not paranoid the DIM is definetly out to get me!
Thanks Eveyone;)
