Fitting G3 brows and lashes to G8
Hi all,
I'm a huge fan of the Oh my! (Lashes, brows and body hair) products. I wanted to fit those to G8, but if I just try that using the fit to option, they end up in the wrong place. The lashes end up somewhere in the forehead for example... How do I fix this?
Thanks a lot,
Me
  • RedzRedz Posts: 1,459
    Hi all,
    Thanks a lot,
    Me
    Hi. If you search the freestuff at renderosity you will find free Genesis 8 refits for Oh My Lashes. I don't think I can direct link. The brows autofit correctly if you choose G3F as the base. They won't match G8F's base texture, but as it's the same texture as Karen 7, applying the Karen 7 Brows morph will match them. That won't be an issue if you're using browless textures though. Hope this helps.
  • Thanks! Is it also possible to fit the Exnem body hair and peach fuzz facial hair to G8?
    Thanks a lot,
    Me
    Thanks a lot,
    Me
    Sorry I didn't make those and I don't own them. Perhaps somebody who does can help you there.
  • alienareaalienarea Posts: 547
    Thanks a lot,
    Me
    The body hair mostly works, you might need some adjustments with the expand/reduce morph. The genital hair of Exnem body hair does not work well with golden palace genitals.
  • Thanks for the replies!
    I did notice that with the Oh My Lashes, there is no "hide transmapped lashes" button in my G8 lashes folder... Is that normal? Can I use the hide transmapped lashes from the G3 folder?
    Thanks a lot,
    Me
    Thanks a lot,
    Me
    Genesis 8 doesn't have eyelashes, that's why there is no corresponding morph. They are a separate attachment. You can hide them or turn off the lashs opacity in the surfaces tab.
  • Thank you!
