the Bend Controls for G3M, how to change to un-automated?
MistaraMistara Posts: 38,675
edited August 2017 in The Commons
i'se checking out this product  https://www.daz3d.com/bend-control-for-genesis-3-male-s
but it says automated.
i would not want these kicking in, unless my g3 male is nude.
is there an easy way to make these not automated?
i'd rather dial them in when wanted.
thanks. smiley
Post edited by Mistara on
  • glaseyeglaseye Posts: 1,312
    edited August 2017
    I don't have the male version, but if it works the same as in the G3F version, then everything is manually adjustable. At default the '!Leg bend controller' and '!Hip bend controller' are set at 0%; that means no adjustments. Change the % for a proportionol control of the bend ajustmensts (and you can fine-tune them....)
    (I do notice the dials in the promo images and see it mentioned in the description, so my bet is they work the same in the G3M and G3F version)
    Post edited by glaseye on
    i'se confused now, the promo pic says automated. >.<
    it these are only tied to pose controls, that would be kewl.
    i'm keyframing using the rotation dials - no pose controls.
  • Zev0Zev0 Posts: 7,123
    edited August 2017
    Automated regarding this product means once the products Master Controllers are active the morphs will automatically work when a pose is used. If master controller is at 0, no action is used. Please see promo video of G3F version how it works. The word automation is used because you do not have to dial up the correctors manually, and they will auto dial when controller is active, from which you can customize the automation. All the automated morphs can be manually adjusted as well if you wish once master dial is used. Hope that make sense.
    Post edited by Zev0 on
    tysmiley
