Sickle Rigging and Morphing System
freecomerfreecomer Posts: 0
Just getting started with this software:
In the help file, under Converting Generation 4 Items To Genesis with Transfer Utility, it states “Some distortion will still probably occur, but it can be decreased by increasing the number of smoothing samples in the Smoothing Modifier (and sometimes in the Collision option as well)”
I can’t find how to access the Smoother Modifier or Collision option to change their settings (In the Transfer Utility there is only an option to tick the box for the Smoothing Modifier, and no sign of the Collision option - I know it can be done, but I can’t see how)
Any advice, please?
  • Richard HaseltineRichard Haseltine Posts: 111,992
    Once you have the Smoothing Modifier applied, from the Transfer Utility or from Edit>Figure>Geometry>Apply SMoothing Modifier, the settings will be on the Parameters pane under Mesh Smoothing.
  • freecomerfreecomer Posts: 0
    Now I see it!
    Thank you very much
