Did someone say the Transfer Util works with V4?
wancowwancow Posts: 2,708
I seem to recall someone did, but I can't see how... or did someone spike my coffee with LSD and I just halucinated that?
  • Scott LivingstonScott Livingston Posts: 4,352
    edited March 2013
    I think so, if (and only if) you convert V4 to TriAx weightmap.
    Edited to add: instructions here, in post #5: http://clothingcreations.proboards.com/index.cgi?board=general&action=display&thread=214
    Post edited by Scott Livingston on
  • BejaymacBejaymac Posts: 2,012
    And I wouldn't recommend it, as all converting does is convert the parametric rig to a rough WM rig, which means she wont bend any better and in some cases bend worse than the parametric rig.
  • wancowwancow Posts: 2,708
    okay, just interested to find out if I do that, then fit clothing, then export that clothing to Cr2, would that be a good way to get it into Poser?
  • ReDaveReDave Posts: 815
    Since it's weight-mapped it won't export properly to cr2. Unless you mean fitting parametric clothing to weight-mapped V4?
  • Richard HaseltineRichard Haseltine Posts: 111,867
    DS will export weights to a CR2 - what it won't do is read them back. That's how the export Genesis to a CR2 trick worked for getting the figuer into Poser pre-DSON Importer.
    Oh I didn't know that! Not having P9 nor 2012 could have something to do with it. I just tried it, my text editor refuses to go beyond line one million-something. o_O
