Morph asking for InjDeltas - whatever they are!
SteveM17SteveM17 Posts: 1,061
I have a nAlfred Hitchcock morph in my library, for M4. But when I try to load it it asks for an InjDelta pz2 called Hitchcock which I can't find.
I'm using Ds 4.0, could that be why?
  • Richard HaseltineRichard Haseltine Posts: 112,089
    The files are Poser format, so it has nothing to do with the version of DS you are using - all should import equally well. It sounds as if it's a custom morph, and the shape data is held in a separate pz2 file that should be read in (probably into one of the community channels that are there for that purpose). Assuming this came as a zip, wheer did you unzip itt o and what folders did it create?
  • SteveM17SteveM17 Posts: 1,061
    The download was from sharecg (for some reason I can't find it there now, but it was only the other day, so it should still be there somewhere). I unzipped it in my library. It has two folders, one called Morphs, and one called Runtime. I dragged them out into my library.
    The runtime folder goes as follows: mylibrary/moviestars/runtime/libraries/pose/werts movie stars: which leads to REMpz2 and INJpz2 files named after the characters (for eample BogartINJ.pz2
    The morphs folder, which is where DS is looking for these delta things, has a folder within called moviestars but it is empty.
    Ooops! Problem solved!
    While dragging files around I must've slipped and put the morphs in a folder I shouldn't have. I've found them and they work fine so far. Just me being clumsy!
    (Note to self - don't try to install content after drinkning half a dozen beers)
