Unrolling grid - Solved
Mosk the ScribeMosk the Scribe Posts: 908
edited August 2017 in Carrara Discussion
Is there a simple way to unroll a grid or plane using modifiers?  I think I'd done this a couple of years ago - but can't find the file and having a hard time replicating method. I think it was something using modifiers like bend and twist - and you could unfurl from either end by simply animating one or two properties.
Thanks for any pointers.
Post edited by Mosk the Scribe on
  • Never mind . . .
    A bit more tinkering and found you need to set the Bend angle higher (360, 720) and then just animate limits.
