Triangulate obj
edited December 1969 in Hexagon Discussion
need to load obj into ivy creator but needs to be triangulated first,how do I do this please.
  • GhostmanGhostman Posts: 215
    Select all the faces. Then go to Tools / Vertex modeling / Triangular tesselation
  • edited December 1969
    Thank you Ghostman,easy when you know how:red:
  • stem_athomestem_athome Posts: 526
    Just to add:-
    You can also use "Utilities-> Decimate" and set (in the right hand properties) the level to 1. That will triangulate quads into 2 triangles, whereas using "Triangular tessellation" will split each quad into 4 triangles.
  • CriosCrios Posts: 3,217
    just for curiosity, it's possible do the reverse, go from one mesh from triangulate to squared?
    :coolsmile:
  • RoygeeRoygee Posts: 2,247
    The only app I've seen do that successfully is Blender - then it still leaves a few ti's to be cleaned up manually. Even MeshLab can't get it right.
    Just to add:-
    Thanks Steve,that's handy to know
