Daz animation erro
I get animation from daz as I walk and save and I try to export to 3d max, motionbuilder or iclone so that animations are not being reproduced simply reproduces the first second and as if the rest did not exist in the time line ja until reinstalei daz mas Still continues this error I saved as fbx I leave animations in the timeline I see it being reproduced in the model genesis 3 but in the export to other programs not sure anyone can help me?
  • What is the play range set to? It sounds as if it is using only the default first 30 frames.
  • mindsongmindsong Posts: 1,788
    I believe the export function has a 'range' option as well, double check that it's set to the full range, rather than the 'current frame'.
    --ms
