Create new folder with favorite morphs for use with all G3F instances
I'd like to create a new folder filled with chosen favorite G3F morphs (for example, dial expressions from various packs) so that each time I call G3F, the folder of morphs is present. The "favorites" under Parameters seems to be scene specific, so it's not what I'm looking for. How would I go about setting this up? Thanks!
Unfortunately you need to keep morph directory. because it is path, for all your saved scene, or presets , to load morphs correctly.
when you make new morph or copy and re-name then save as new morph, you can decide install path as you like.
or you can set group (in ds parameter it called "path" but it is not installed path, group name of parameter),
then save again those (overwrite which saved before). it not change installed path, and morph name, just change group name. then may not cause many problem.
but may better ,first test only about your hand made morphs. (or keep copy of original, then easy return default).
once you modify and save morph, your modify can not be return, untill you re-install morph again.
Then I can not recommend, change something about product morphs, because it easy overwritten when vendor up-date. then can not confirm, when daz change way,
(eg it not cause problem but it may cause problem about future version)
You could create links to them by creating custom morphs that activate them, and then saving them all to the same library; you could have them all in the same place, under the same heading or group of headings.
You could also save the morphs you want as new morphs with a new name to the same group or groups; I'm loathe to suggest it though, as I imagine it could be easy to mess something up.
Make backups of your Studio Installation and Asset folders first.
