tricot shaders
Is there tricot shaders for iray (google "tricot leggings or nylon trico" so you can see what i mean). There is abicail outfit and its addon https://www.daz3d.com/abigail-textures that has something close to that and there is fashion leggings https://www.daz3d.com/fashion-leggings-for-genesis-3-female-s. But is there shaders or does fashion leggings have shaders also in it.
  • scorpioscorpio Posts: 8,533
    It looks as if the fashion leggings does also have a shader preset, Mec4D's PBS Shaders vol.2 for Iray has some Latex presets. It shouldn't be difficult to do yourself using the Uber Iray shader alter the surface setting until you get what you are looking for, if you are using Iray if 3dl then the uber Surface shader or even just the 3dl default.
