Genesis 8 disappearing in Hexagon
Having a little problem with Genesis 8 in Hexagon. When I send G8 to Hex from Daz the figure is invisible until I select it, and goes invisible once I select something else. The figure is set to visible in the scene tab. Not having this issue with any other figures / objects. Just G8 (and the eyebrows). Any ideas?
Hexagon does not seem to like iray materials & works better if you send G8 over the bridge in 3DL
There is a free grey preset on sharecg which may help - https://www.sharecg.com/v/88716/browse/21/DAZ-Studio/Genesis-Grey-Materials-G8F
That did it. The IRay gray did the same thing but the 3Delight gray worked fine. Thanks.
