Using custom GenX2 morphs for G2F on G3F
Is there a way to use the morphs generated in GenX2 for G2F on G3F?
I can't get the original V4.2 custom morphs (pz2) to work straight from V4.2 to G3F. Thanks!
  • LeanaLeana Posts: 13,516
    You can't use a G2F morph on G3F, but you could always try converting the G2F version to G3F via GenX2.
  • NovicaNovica Posts: 23,925
    I'm not real sure what you're asking. For the second one though- Do you have the G2 and G3 products for GenX2?  They are required to take anything from Generation 4 to Genesis 3.  While it appears you can just go straight to Genesis 3, it does require the Genesis 2 products for GenX2 to do that.
    Also, you might want to look at the link in my signature and see if that GenX2 tips section answers your questions.
  • JoltrastJoltrast Posts: 208
    edited August 2017
    Novica said:
    I own all the GenX products and they are correctly installed. I'd like to use a custom morph which was created on G2 from a V4 morph and use it on a G3 model using GenX2.
    Post edited by Joltrast on
