OT - got a couple of loose screws - or screws loose -
namffuaknamffuak Posts: 4,514
Yeah, I've been accused of this for years, but this time it's serious. I was swapping around my gpus and managed to drop two screws into the system - and I can't find them. I've tried shaking the case (gently) and using a high-intensity flashlight at an angle and nothing is showing up.I don't want to get too agressive on moving the wiring, my manual dexterity has gone downhill since I used to do this sort of thing 15 years ago.
Suggestions?
    Are you positive they're in the case and didn't bounce out somewhere else, like the floor?
  • StingerStinger Posts: 328
    They could have gotten wedged between the motherboard and the back of the case.  Might have to remove the motherboard to be safe.
  • namffuaknamffuak Posts: 4,514
    Well - it turns out the one bounce a foot away on the floor; one down, one to go.
    If it comes to that, the box goes off to my local repair shop. I'm bound to do something worse than just the screw if I try to do anything major.
  • xyer0xyer0 Posts: 6,507
    In the old days they used alum for that.
  • srieschsriesch Posts: 4,243
    A vaccum cleaner, around the inside of the case?  Might dislodge it, hopefully you'll hear the screw bounce around when it gets sucked up.  Same could apply to the floor if you dropped it like the other but didn't see it.  Although I vaguely recall something about vaccums and static charges.
  • ZyloxZylox Posts: 787
    Using a vaccum on a computer is NOT a good idea. The air flowing into the vaccum creates static electricity which can fry the delicate circuits inside a computer.
  • TaozTaoz Posts: 10,346
    Suggestions?
    Happened to me too a couple of times, just turn the case upside down and on all sides, usually you can hear the screw rattle around unless it's stuck somewhere. Just shaking the case is not always enough.
