Poke-thru question
Drogo Nazhur
Referring to th attached image, the guy on the left is clearly bigger than the guy on the right but his clothes fit fine while the guy on the right is poking thru his clothes. Why? And how do I fix that?
Thanks in advance for any suggestions.
1001 x 1250 - 862K
Is this a 3Delight render? The one with poke-through looks like he has a fair bit of either displacement (which doesn't work as well in Iray rendering) or HD vein morphs — the problem being that the clothes will follow the whole-body morphs on the figure, but can't follow any displacement or fine-detail HD morphs added on top of that.
One solution might be Mesh Smoothing on the shirt and trousers; if it's already applied, you might need to adjust the smoothing parameters.
For well-covered body parts like the legs, the easiest solution is to simply hide those body parts.
