Td3d - Electric Guitar Set Freebie
Td3dTd3d Posts: 412
edited August 2017 in Freebies
This is a sample of what I got coming. Had to try out some ideas. These are very basic and have only a default Iray texture. I don't have the time to create poses for these ones and well, they may as well be earning zero in your runtime also. If you like these, you'll like my even better set better when they're done.
Hope you enjoy them ppl :)
Google Drive Link to Td3d - Electric Guitar Set: https://drive.google.com/open?id=0B-YRJZ4329t-azJzQ2dhb2M4dDA
1300 x 1000 - 276K
zip
zip
Td3d-ElectricGuitarSet_Templates.zip
78K
Post edited by Td3d on
  • AndySAndyS Posts: 1,447
    edited August 2017
    Hi,
    the props look nice.
    But there are some missing files or misplaced files on loading the props.
    (see attachment)
    P.S.
    Ah, perhaps you sould say, that the guitar has to be parented to the stand first, before using the pose preset: "place on stand".
    506 x 466 - 39K
    Post edited by AndyS on
  • Td3dTd3d Posts: 412
    edited August 2017
    Thank you Andy, Am looking at that right now. The file it wants is actually in the newly named /Electric-V MkII/.. folder. It is for the trussrod cover. My deepest appologies. I have saved a new file and updated the .zip on drive. In the shorter term, just point it towards the file shown. Same file different folder name.
    As for the stand, It is just thrown in there. It belongs to a set I am having poses made for and wanted to test the idea of a rigging template for my guitars. These sitting on the stand were what I needed to see that it worked. My tester is not a PA, so there were complications why I couldn't sent this set to him (was originally meant for a larger package). I just checked that again and well, load the guitar and stand, select the guitar in the scene and click "place on stand". ...done. I just tried them both again. But yes, if you parent the guitar to the stanf first you can place the stand anywhere and the guitar will go to it. Though it will land on the stand if they are in the un-parented default load position and then parented also. This is exactly why I get other people to do my posing stuff) But it won't let me save as a parented prop because they are not weightmapped or something. Could save out a parented sub-scene, but you'll have heaps of guitars to get rid of and things to delete if you only want a guitar or stand.
    Oh, if you look in the Parameters Pane, you will see a morph to adjust the stand height, so you can use it with other guitars. It will load @30% by default for these two guitars.
    The link is the same, it has the updated (prop and default mats) file saves in it: https://drive.google.com/open?id=0B-YRJZ4329t-azJzQ2dhb2M4dDA
    I've attached them here also.
    670 x 457 - 112K
    duf
    duf
    Td3d - !Electric-V MkII.duf
    155K
    duf
    duf
    Td3d - Electric-V MkII !Default Mats.duf
    295K
    1272 x 883 - 247K
    Here's a preset if you own the Stellacaster Guitar and poses set (and the freebie stand has been installed that is). The info on the .png can be applied to the othrs also.
    duf
    duf
    Stellacaster - Place on Stand.duf
    532B
    250 x 250 - 78K
  • SkelchSkelch Posts: 276
    Thank you this is nice
    edited August 2017
    Nice one ANGELREAPER1972! Love your work, so I know that these are just a precurser to an even bigger scene. Awesome :)
    Here's a tip... all these guitars were made (rigged) upon the same scaling template I made (basses included). What ever poses you create for these guitars can be applied to all of them. Have tested the theory and it works well. Reffer to images. Here's how to do it.
    - Pose your Base Character (Genesis to Genesis 3m/8f)and one guitar (unparented)
    - Copy the Guitar Translation Only (X,Y,Z's etc).
    - Load all guitar (Super-V, Electric-V MkII, HB-Acoustic, HB-Electric and T-Bass) and from Zoro position, Paste those parameter settings ("paste pose to selected object?" - click Yes).
    - Once all guitars are in that pose, Parent them ALL to the Left Hand (or where-ever).
    - Save out the Character pose a s a HPP (making sure that you include all guitars in the preset)
    - Load a scene, Load any one of those guitars Make sure it's parented to the Character's ( All these came with a universaly standard Wearable preset anyway based upon this guide) and use the saved HPP.
    - When you use that preset it will pose what ever guitar you have in the scene. The others don't have to all be loaded.
    These images will show you what I am talking about. Everything pivits at the 14th fret. Perfect for posing them. You will only have to tweak the parented hand/wrist to get the guitar to look good (due to body shapes) However the guitars will all slide perfectly through the hands due to their correctly shaped necks. Any hand presets you have made will work on any of them due to this.
    Thanks again for sharing these images. Hope you can get some value from this tip :)
    624 x 830 - 238K
    624 x 830 - 171K
    1223 x 830 - 440K
  • dHandledHandle Posts: 617
    I grabbed this one, too!  Great work, very realistic.
    Thank you!
    Now, anyone know where I can get a...what's the correct name...plectrum?   (A  pick?)
    dHandle, These two sets found here at Daz3d have one of those.
    https://www.daz3d.com/the-stellacaster-guitar-and-poses-for-genesis-3
    https://www.daz3d.com/ef-acoustic-guitar (Victoria 4, Michael 4)
    The Stellacaster Guitar and Poses for Genesis 3 in Vendor, Navi,  3D Models by Daz 3D
    Thank you!
    Td3d said,     "dHandle, These two sets found here at Daz3d have one of those.
    https://www.daz3d.com/ef-acoustic-guitar (Victoria 4, Michael 4)"
    yeah, I saw those.
    I need to find a freebie.
    Maybe I could model my own in 3DS Max....
  • ANGELREAPER1972ANGELREAPER1972 Posts: 4,565
    edited August 2017
    hot rocking
    all guitars created by Td3d
    on bass Victoria8, guitar Mei Lin7, singer Ophelia, drums Victoria 6, guitar Olympia8 (with new texture via facegen), on guitar Daphne (Olympia Pro8 character)
    Made with...
    Post edited by Chohole on
  • thanks, had a go at your tutorial I'm not doing something right I'll keep trying
  • SaphirewildSaphirewild Posts: 6,680
    edited August 2017
    hot rocking
    Made with...
    The lady in front reminds me of Brittany Spears great render!!!!
    Rock on Ladies!!!
    ANGELREAPER1972, Here's a better visual "tutorial" of what I was explaining. Hope it is helpful.
    Link to .wmv tutorial: https://drive.google.com/open?id=0B-YRJZ4329t-RHRPelRfdWNNUkk
  • KeryaKerya Posts: 10,943
    Thank you!
    http://lab108.x0.com/lab108/inst.html
    (15th from bottom)
    Kerya said:
    Thank you!
    (15th from bottom)
    Looks like that will work!  Thanks @kerya
  • thanks Saphirewild interesting about Brit
  • thanks Td3d I've tried creating my own sort of bass pose using this method using parts of yours and a few others then manipulating it more only thing can't find the pose to load it first saved it in the default Hp folder then tried in my own folders where I have saved scenes and other stuff I've done  but none of these show up in any of my menus we're getting there
    edited August 2017
    couple new ones using your bass one with the hat pose tried creating combining your hand poses with some others then I tweaked bit more
    https://www.daz3d.com/gallery/#images/418366
    https://www.daz3d.com/gallery/#images/418371
  • MartialMartial Posts: 431
    Many thanks for yours guitars Here a sample from a work in progress using them
    2931 x 3579 - 3M
    Martial said:
    Many thanks for yours guitars Here a sample from a work in progress using them.........
    couple new ones using your bass one with the hat pose tried creating combining your hand poses with some others then I tweaked bit more..........
    Wow! absolutely love these images. Great use of these guitars ANGELREAPER1972 and Martial. I still haven't had a chance to do anything myself, so this is great seeing what you guys are doing. If this is a work in progress, I am keen to see the end result.... :)
  • keekerkeeker Posts: 48
    edited February 2018
    Thanks for the hard work.  Outstanding guitars!
    Post edited by keeker on
    Thank you for the feedback good ppl. Have had a lot of downtime. Done a huge relocation up to the rainforest with a new computer and some nice software to get my head around. Satelite internet, makes time online limited though. Good to go again just the same :)
    ...again thanks for the support.
  • really good to see you back
    Great to see you back Td3d!!
    Looking forward to seeing some more great props in the near future!?
    Hi Saphirewild, and thank you. Yeah it's been pretty busy here. Just released a new product with poses ( https://www.daz3d.com/nostalgic-camera-for-genesis-8 ) and am frantically creating some even bigger stuff to get the year rolling as it should. One of my projects will heve a few leftovers (test/conceptual versions) that won't be in the final packages. They will surely make it into your freebies forum :) ...be later on though. ...am playing serious catch-up atm :)
  • OshikaiOshikai Posts: 21
    Thank you.
