Measure Metric
Loaded a Genesis 3 Male Character.
Loaded Measeure Genesis 3 Male which adopts the pose and the nodes appear.
After that nothing works. Measure metrics wont load.
Please give me a step by step in case I'm doing it wrong
Thanks
Thanks
Have you entered the Measure Metrics serial number in Help>About Installed Plug-ins? Did you actually install Measure Metrics (the parts you describe are Figure Metrics, a script and support files that use the MM plug-in).
Make sure you've input the serial number. Otherwise it won't work.
Hello,
I previously entered the SN, however when I checked although the SN was there, I had to reinput it and restarted Daz before ir would work.
Thanks for help.
