Iray doesn't seem to use my GPU
Dear Daz-users!
I know there are a lot of posts about similar issues but I've found nothing that adresses my problem entirely.
I recently bought an Nvidea gtx 1060 6gb to use with iray. I go to render settings and mark both cpu and gpu and hit render. It then renders at the exact same speed as with my old gtx 570... I go there again and uncheck the cpu so it should only use my new 1060. It starts rendering and after about 5 seconds it's "finished", but nothing is rendered and it's just the empty grayish square pattern as unrendered.
Has anyone had this problem? It shouldn't be a memory issue and the drivers are up to date. I think that maybe my old gtx 570 never worked either and I just assumed it was too slow.
I'm sorry if there already is another post on exactly this issue but as far as I can tell there is none. I appreciate the help very much!
Can you render a simple primitive (Create>New Primitive, set it to sphere or cube) in an othrwise empty scene? After you try rendering open the log file (Help>Troubleshooting>View Log), scroll to the end, and then look back until you find the beginning of the render process: paste that block of text here.
2017-25-03 22:25:06.285 WARNING: libpng warning: iCCP: known incorrect sRGB profile
2017-25-03 22:25:15.205 Rendering image
2017-25-03 22:25:15.216 Iray INFO - module:category(IMAGE:IO): 1.0 IMAGE io info : Loading image "C:/Program Files/DAZ 3D/DAZStudio4/shaders/iray/resources/DTHDR-RuinsB-500.hdr", pixel type "Rgb_fp", 512x256x1 pixels, 1 miplevel.
2017-25-03 22:25:15.235 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating geometry.
2017-25-03 22:25:15.235 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Using OptiX Prime ray tracing.
2017-25-03 22:25:15.250 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Geometry import (1 object with 1k triangles, 1 instance yielding 1k triangles) took 0.000303
2017-25-03 22:25:15.250 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating materials.
2017-25-03 22:25:15.250 Iray INFO - module:category(MATCNV:RENDER): 1.0 MATCNV rend info : found 1 textures, 0 lambdas (0 unique)
2017-25-03 22:25:15.250 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating environment.
2017-25-03 22:25:15.258 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating lights.
2017-25-03 22:25:15.259 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating object flags.
2017-25-03 22:25:15.259 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating caustic portals.
2017-25-03 22:25:15.259 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Updating decals.
2017-25-03 22:25:15.264 Iray INFO - module:category(IRAY:RENDER): 1.0 IRAY rend info : Using batch scheduling, architectural sampler disabled, caustic sampler disabled
2017-25-03 22:25:15.264 WARNING: dzneuraymgr.cpp(261): Iray ERROR - module:category(IRAY:RENDER): 1.0 IRAY rend error: Cannot render: found no usable devices.
2017-25-03 22:25:15.264 Iray Render error: Invalid parameters (NULL pointer).
2017-25-03 22:25:15.346 Saved image: C:\Users\Petter\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2017-25-03 22:25:15.358 Finished Rendering
2017-25-03 22:25:15.392 Total Rendering Time: 0.24 seconds
You mean like this? Took all of what was rendered today. "Cannot render: found no usable devices" sounds nasty...
Thank you Richard for the quick reply!
Which version of Daz Studio are you using? - Pascal cards only work in 4.9 - (4.8 will give the no usable devices message)
Have you updated your Nvidia Drivers (The latest version I use is 384.74)
Ok I solved it by installing the beta of the new DAZ version and updating the NVIDEA driver. Don't know which one of those tthat solved it? Probably both.
Thank you both for the help!
