How to refresh images for renders
Hi,
I'm using IRAY in Ds 4.9.4 ( I believe the latest version)
 I have figured out how to refresh images, however I am having problems with the renderer refreshing the images.
For instance if I am working on creating a texture:
I render the texture and find something I want to change.
I change the texture in Photoshop
I update the texture with the surface tab refresh textures and automatically update textures.That works fine
Unfortunately once the images are refreshed they still render the previous image before it was corrected
Is ther a way to clear the previous texture from the render's memory so I can render the update.
Cheerio
lululee
  • Collective3dCollective3d Posts: 446
    edited August 2017
    Sometimes re-saving the texture in Photoshop is necessary.
    Beyond that, a sure way to fix it is to completely re-start the app.
    Post edited by Collective3d on
  • lululee1lululee1 Posts: 346
    Hi Collective3d,
    Thanks for the valuable info.
    I did resave in Photoshop a second time and it seemed to work.
    It is very frustrating when developing textures to have to restart the app every time I make a slight change so I appreciate your help..
    Cheerio
    lululee
  • SzarkSzark Posts: 10,634
    I use a combination of the Purge Memory Script in the Scripts Content Folder and Refresh Image function in the Surfaces Pane.
  • Pack58Pack58 Posts: 750
    I'm still working with 3DL in 4.7 but every time I alter a texture on the fly I save as a new file name and load that and then have no need to refresh  etc.
    'Corse I need to tidy up the folder at some stage (or get bigger 'n' bigger drives).
    Hi,
      Thanks so much for all of your help.
    I'm going to try all of them.
    Cheerio
    lululee
  • FistyFisty Posts: 3,416
    I just save as a new name each time..  dress test 1, dress test 2, etc..  once I have a final I like I save it as the real file name I want.  It's a pain in the butt bug that's been around seemingly forever (at least since DS3), it's worse with Iray.  In 3DL you >usually< get 3 or 4 changes before it stops working, with Iray you're lucky if you get one.
  • 3Diva3Diva Posts: 12,058
    I'm having the same issues with my texturing. I find doing what Fisty suggests works. I just save the changes as JPGs while testing, but when it's where I want it, I save the final as PNG.
    Thanks fisty and divamakeup.
    I guess I'll have to do save changes in different names. Grrrhhhh!
    i could not get the "purge from memory" to update the render images.
    Hopefully they'll fix that bug soon. it is very time consuming.
    Cheerio
    lululee
    strange I have no issue when I use a combination of the two. One of those some have it some don't bug...hard to track those down.
  • pdspds Posts: 593
    I've run into this problem and ended up doing what Fisty said. And doing as Diva suggests and saving the best variation as a png will definitely help when it's time to purge the draft iterations, especially if your final test isn't the keeper.
  • GatorGator Posts: 1,320
    This is what I've resorted to doing too.
