LAMH not loading
leo04leo04 Posts: 415
I have the latest version of LAMH but it wont load.
First image is the setup in IM to load...they are both selected and then I click Start Queue
Second is after the IM runs...if fails to load one and the other is "loaded" but shows not files.
The only manual I can find is for Version 1.5.
Any help?
Update: after playing around some I have gotten this far, but cannot edit anything and not getting the tool bar. see last  posted image...
1148 x 532 - 96K
1148 x 716 - 97K
410 x 765 - 51K
Post edited by leo04 on
  • Richard HaseltineRichard Haseltine Posts: 112,087
    Did you allow DIM to run with Elevated privileges? (Say Yes when asked if you anted to allow its helper to make chnages on this computer, that is.)
  • leo04leo04 Posts: 415
    edited July 2017
    Yes..when IM starts it does ask if it can make changes..I accepted...
  • fixmypcmikefixmypcmike Posts: 19,743
    Don't install both the full LAMH and the Player.  If the Player installed successfully, uninstall it and then install the full version.
    edited July 2017
    Aready did that still not getting the tool bar. Also I never got the startup page shown in the manual...BTW I am running DS ver 4.9.4.117 64bit on Win10.
    Also after doing that I dont seem to have any files installed...see image
    957 x 442 - 159K
    1148 x 716 - 93K
    edited July 2017
    Update: I finally found what I think was part of the issue, a file; lamhplayer.dll, was floating around and I deleted that and I stopped getting the error about having the player loaded.
    I think the problem now is I have to install it on the C drive and I need it installed on the "D" drive. (not enough room on "C").  This does not seem to be an option and I am not sure what to do.
    Help please.
    495 x 96 - 14K
    IIRC, you don't need to install all your content to the C: drive, Lamh just needs to create one folder there.
    Okay, so I finally got it to work. Seems you have to have a path on the "C" drive regardless of were you have things installed.
    I see this is a flaw and it should be fixed.  My DAZ is installed on "D" because I simply do not have room on "C".
    Some installation instructions might help too. I spent the entire day trying to resolve the issue.
    Thanks for all the help...now I just have to learn how to use it.
    Thanks everyone.
