How does my PC build look? Any comments/advice would be great
5200north
PCPartPicker part list: https://pcpartpicker.com/list/pJcKm8
Price breakdown by merchant: https://pcpartpicker.com/list/pJcKm8/by_merchant/
CPU: AMD - Ryzen 7 1700X 3.4GHz 8-Core Processor ($339.99 @ Newegg)
CPU Cooler: Cooler Master - Hyper 212X 82.9 CFM CPU Cooler ($24.99 @ Newegg)
Thermal Compound: Arctic Silver - 5 High-Density Polysynthetic Silver 3.5g Thermal Paste ($5.95 @ Newegg)
Motherboard: MSI - X370 GAMING PRO CARBON ATX AM4 Motherboard ($161.98 @ Newegg)
Memory: Corsair - Vengeance LPX 32GB (4 x 8GB) DDR4-2666 Memory ($277.99 @ Newegg) NOTE 2
Storage: Samsung - 850 EVO-Series 1TB 2.5" Solid State Drive ($339.99 @ Newegg)
Storage: Western Digital - Blue 4TB 3.5" 5400RPM Internal Hard Drive ($117.99 @ Newegg)
Storage: Seagate - Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($138.98 @ Newegg)
Video Card: EVGA - GeForce GTX 1070 8GB FTW HYBRID Video Card NOTE 1
Case: Corsair - Carbide Clear 600C ATX Full Tower Case ($129.99 @ Newegg)
Power Supply: EVGA - SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($81.98 @ Newegg)
Case Fan: Cooler Master - MasterFan Pro 120 Air Flow 84.5 CFM 120mm Fan ($17.99 @ Newegg)
Other: Mailiya PCI-E to USB 3.0 5-Port PCI Express Card with 15-Pin Power Connector and 1 USB 3.0 20-Pin Connector for Another 2 Ports [ Include with A 4pin to 2x15pin & A 15pin to 2x15pin SATA Y-Cable ]
Total: $1655.81
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2017-07-29 02:55 EDT-0400
1. If I can get a 1080 cheap via ebay or another good sale I will
2.is this memory good
3. I'm going to custom paint the case (orange ) and may paint some parts inside
CPU Cooler : The 212X that you have listed does not have a socket AM4 bracket in the box, you would need to order it from Cooler Master. (The 212 Led Turbo and the 212 Plus have it in the box)
I already own the SSD, the Seagate 1TB drive and the usb pci card.
Water cooling makes me nervous, is there another cpu fan I should consider?
The case is expensive but I was killer case and I love this one.
I have no issues with the cooler you have chosen (other than needing to choose one that comes with the socket AM4 bracket), That build style is very good at moving the heat away from the CPU and sending it in the direction you want it to go (directly into the can venting out the back of the tower in my builds)
You do not need to consider liquid cooling unless you are planning to massively overclock your CPU.
That makes sense why you seem to have a random assortment of drives. (you might still want to look into getting a pair of those WD SSDs to run in raid though. plus they have a 5 year warranty)
You have enough USB 3.0 ports on that motherboard, tha tI would not bother with adding in an extra card
Have you checked out the Corsair Carbie 400C as well? Similar styling but a bit smaller. Still has good airflow. Maybe 30 - 50 bucks less. Could save another 50 bucks or so by going with the Ryzen 7 1700 instead of 1700x. By most professional review accounts, they're practically identical sicne you can overclock it.
If you could add the fans later, or just get by with the stock fans, that'd save you another 40 bucks or so. So that gives you another 120 or so to upgrade the gpu or grab faster RAM. Ryzen appears to benefit from faster ram more than other processors. You could also add the 4TB drive later to save another 100 bucks for right now. That puts you into the range of an air-cooled gtx 1080ti, like the Asus Strix or MSI Duke models.
Also, once you have everything together, make sure you have updated AMD chipset drivers: http://www.amd.com/en-us/products/chipsets/am4
That is very good advice but i really want to try to custom mod a case, noting complicaed just an orange finish and maybe a few custom add ons. i found a custiom build website that sells these large metal buttons for the powere switch that i'm dying to get.
