Veins and Blood
AloreeaAloreea Posts: 285
Ok so, I am trying paint veins on a model of mine. I want them to be barely visible, where you can still make out the blue. Where would I paint them? On the Texture map? Or Translucency map?
Also one more question... smiley  If I wanted to show the blood in the tips of her fingers and toes, where would I paint that? Translucency or Texture?
Sorry for the questions, I'm new to this stuff. Thanks in advance!
  • kyoto kidkyoto kid Posts: 42,399
    ...what figure are you using?
  • AndySAndyS Posts: 1,449
    Hi,
    you put the veins into the translucency color. Better is to mix the vein map with some kind of diffuse for that pupose.
    Over here is a link to some vessel maps.
    For an own test with the (G1)Aaron skin, which uses the V4 UV, I mixed the vessel map with the skin texture using the multiply layer algorythm in a photoshop similar program. In a second step I adjusted brightness and gamma of the result to match the original skintone. This I used in the translucency color channal at 35% (scatter & transmit).
    The result:
    https://sta.sh/023m8d4xu7lb
  • AloreeaAloreea Posts: 285
    edited July 2017
    I'm using Genesis 3, I also plan on painting them on a Genesis 8 map too.
    Post edited by Aloreea on
    AndyS said:
    Hi,
    The result:
    Thank you so much for your help!
    AndyS said:
    That's very helpful, thanks alot! smiley trying to figure it out was driving me crazy!
