Property to All key frames
hazneliel_cc85b88108
Hello, I made an animation with several key frames, now I decided to change for example the hip size of the character. How can I change it for all the key frames ???
eg if you want to change hip size by "hip volume" motph in shaping tab,
go to "zero" frame, then change the value as you want.
(I do not know which morph you may use to change hip size)
or you may use scale property of plevis then you can change hip size.
on zero frame.
if you do not use and change the value on another key frame,
the morph may keep the value untill last frame,
but ,, on 5 frame, you changed hip size 20, on 10 frame , changed hip seze 10,
they are already recorded as new key frame about the node.
after that you need to change hip size to 30 about all frame,,
you may need to change hip size value, on each key frames you made .
on this case,, most simple way seems reset the value of morph or parameter
which you used .
I change plevis size, on some frames. then reset the value to zero.
( there is no difference which frame you reset,)
it can reset the property (eg plevis scale value to zero ) about every frames. all key of the property are removed
after that, change hip size on zero start frame.
(or recommend you get key mate,,, it can copy and paste each property value to another frame easy,
you can select and check some frames at once too)
http://www.daz3d.com/keymate now it seems discount price.
