Figure Metrics/Measure Metrics bug(?) *SOLVED*
pfunkyfizepfunkyfize Posts: 496
Hi all,
I just used Measured Metrics script for the first time in a couple months and saw that changing the unit of measurement from cm to in no longer does the conversion. So if I looked at G3F's height value which is 179.85 cm and change the unit of measurement to inches, the 179.85 value stays unchanged where in the past the value would change and convert to the inches equivalent instantly. I have uninstalled and reinstalled the figure metrics script through DIM and restarted my version of Studio (The most recent updated version) but no dice. Still won't work.
Anyone seeing the same behavior in the Measure Metrics/Figure Metrics script?
Thanks!
Post edited by pfunkyfize on
  • reelyorreelyor Posts: 237
    Yes. It seems to be needing an update, when Rob at Daz has time to do so.
  • pfunkyfizepfunkyfize Posts: 496
    Thanks for confirming!
  • fastbike1fastbike1 Posts: 4,083
    edited July 2017
    I'm not quite seeing that in Measure Metrics. I can start w/ in and change back and forth to cm. I can start in cm and change back and forth to in. This is in Measure Metrics. In Figure Metrics you seem to have to check/uncheck a box to get the change to update. This seems to work only for the dimensions with check boxes
    Post edited by fastbike1 on
    Unfortunately, I am seeing the non-changing behavior in measure metrics... I start with cm with the centimeter value but flip to inches and the centimeter value doesn't convert at all to inches....
    In the figure metrics dialog box, toggling the checkbox would change the value but the changing of the units drop down used to change the value to the appropriate unit value. Now it no longer does that.
    AWESOME!
    The Figure Metrics utility was recently updated and the units drop down works while changing the units !
    Thanks DAZ!
