Whole Lot of Piranhas ears
CypherFOXCypherFOX Posts: 3,401
Greetings,
Okay...where do the ears come from?
They're not listed on the Piranha Zipper Dress product. I'm hoping it's something I have, because they're adorable.
More than that, I want to know if the Whole Lot of Piranhas really comes with matching textures for those ears, because that's freaking adorable, and does a great job of softening the whole look.
Thanks for any pointers!
-- Morgan
    edited March 2013
    Think it comes with the Hair. Looks like an Aprilysh set.
    EDIT: http://www.daz3d.com/tandy-hair
    Post edited by Mattymanx on
  • SpitSpit Posts: 2,342
    Yeah, I wager it's April's Tandy.
    Greetings,
    Thanks Mattymanx and Spit!
    Wishlisted for better days. Adorable... :)
    -- Morgan
    There's also Catgirl for Genesis which has ears and a tail which you can attach. The catch is that the textures supplied are more cartoony than realistic, but with them scaling appropriately for the character you place them on, it could be worth a look.
    Not compatible with V4, of course, but it might be worth a look if you planned to use them in future work.
  • Pixel8tedPixel8ted Posts: 613
    The cool thing is that the dress is using a shader so you can select the surface of the dress with the fur preset applied then save it as a shader preset. I did that to texture up a pair of shoes to go with the fur textured dress.
  • 4blueyes4blueyes Posts: 153
    Yep, what Pixel8ted said :) We made special effort to have tileable shaders for the outfit and the addon, so that the shaders can be easily copied to other clothing items in the scene to match, and this is what was used for the Tandy Ears prop by Bucketload3D (the only non-tileable shader is the zipper).
    1. Select the Piranha clothing figure with the shader you want to save
    2. in the Surface Tab select the needed material
    3. In the Content tab click the + button at the bottom of the tab and select Save As Shader Preset
    These are not merchant resources and you cannot share the shaders with other users, but you can easily use them now for your own needs on other clothing items, props or whatever you feel like using it on.
    Hope it helps :)
    Michal
    4blueyes
