temp() and tempPath() not working, or is it just me?
morkmork Posts: 278
This throws an error for me:
// DAZ Studio version 4.9.4.117 filetype DAZ Script(function(){var foo = DzDir.tempPath();print(foo);// Finalize the function and invoke})();
Error:
Script Error: Line 5TypeError: Result of expression 'DzDir.tempPath' [undefined] is not a functionStack Trace: ()@:5
It might be on my side only, because I run DAZ through WINE on linux, but please don't stop reading just because I mentioned linux. :)
I'd like to know if someone can reproduce this error, please. :)
Edit: I need to mention that creating directories, files and copy files does work flawlessly.
Thank you very much
-mork
Post edited by mork on
  • morkmork Posts: 278
    I worked around it for now by using a environment variable (System.setenv, System.getenv). That works per session only, but better than nothing or writing to some random dir.
  • SimonJMSimonJM Posts: 6,103
    Just tried it myself, DS4.9.4.115, 64-bit, udner Win 8.1, and:
    Welcome to the Qt Script debugger.
    Debugger commands start with a . (period).
    Any other input will be evaluated by the script interpreter.
    Type ".help" for help.
    3 (function(){
    Uncaught exception at <anonymous script, id=646223264>:5: TypeError: Result of expression 'DzDir.tempPath' [undefined] is not a function.
    5 var foo = DzDir.tempPath();
    Thank you!
  • jag11jag11 Posts: 885
    Why not use:
    print(App.getTempPath())
    Uhm, because that's too easy! Nah, just kidding, it works, thank you very much!
    I'm still digging into the API, I saw that method on DzDir and did not know it is also on DzApp.
    Thank you for that hint!
    In Daz Script (ECMAScript 5.1 - protypal inheritance model), an instance of the Dz* object is still needed to access its "static" methods. The methods listed in the "static" section of Dz* objects are only "static" in the sense that they do not operate on the instance itself, rather they operate as though they were defined on the prototype of the object in the context of any (all) instance(s).
    Ah I see, that is helpful to know, thank you!
