Genesis Hair Morphs (PH Lovely)
sandmanmax
I've loaded up Aiko 5/Genesis in Poser Pro 2012. I loaded Pure Hair Lovely from the MyLibrary runtime - it's a cr2, not a prop. I ran the DSON Transfer Active Morphs script and it popped into place and fit Aiko5 perfectly. The problem is I can't find any morphs. When I loaded Aiko5 and PH Lovely in DS4.5, there are a bunch of morphs, like movement and length. So how do I get the morphs into this thing? I've had the same problem with clothing.
Never mind... I found them. When you select the Body, there's a parameter group called Actor. Expand it and there are all the morphs. I'm used to looking at either Head or Neck for hair morphs.
