Only 7 light sources show up when Preview Lights is on?
If I add 8 spotlights to a scene, only light sources will show up.  Is this a setting somewhere?
If I render, the light source will show, but not in any preview mode. If I delete lights (say light #4), the 8th light will pop on since there are only 7 lights.
  • Richard HaseltineRichard Haseltine Posts: 111,348
    This is correct - most GPUs are limited to 8 lights in OpenGL, and one is taken by the camera headlamp. You can use the Render Priority setting (in the Parametrs pane) to cotrnol which lights render.
