2 Questions
I was trying to use my space navigator and lost my scene. I tried to move it back to the default view but i can't figure out how. I even closed the program but it came back just where I left it.
1. How do I get back to the default view?
I purchased the victoria 8 and Lanie models as well as the Lanie bundle. I cannot get the hair to take a color and.... there is a white base cap on her head even after her skin is applied.
2. How do I color her hair and remove the white cap?
  • JCThomasJCThomas Posts: 254
    1 Select something in the scene tab. press CTRL+F. It'll focus on the selected object.
    2. Select the hair. Color options should appear in your Smart Content tab.
  • libbylibby Posts: 8
    edited July 2017
    Thanks JC!~
    ok the first worked well thanks!! BUT the hair just isnt working
     I selected the color but the hair stays white
    Post edited by libby on
    Is there a tech support for folks who need help? The forum seems to be hit and miss and is there a chat? or a skype channel? or a phone number?
    There's not... there are some youtube videos that might be helpful.
    What hair are you trying to use?
    edited July 2017
    First, I strongly suggest you use the Content Library Tab since "Smart Content" isn't very smart
    1. Load the hair
    2. Select the hair (see Capture 2)
    3. See Capture 1 The Path should be Genesis 8 Female>Hair>OOT Lainey Hair>Mats>Iray . Note the Icon that says "APPLY FIRST Hair Base Material". Double click this icon.
    4. See Capture 3. This apparently makes the cap transparent and applies a base shade to the hair
    5. Double Click the shade you want to apply. See Capture 4
    445 x 895 - 72K
    714 x 694 - 87K
    704 x 733 - 51K
    648 x 730 - 51K
    Post edited by fastbike1 on
    Thanks so much guys. I'll do the content tab and try again.Will let you know if that helps.
    ok I did every step again. Still have that cap and white hair, still have white clothing
     is it possible that I need to uninstall and reinstall everything including Daz?
  • Richard HaseltineRichard Haseltine Posts: 111,192
    Reinstalling is very unlikely to help.
    Are you sure you are selecting the hair or clothing before applying the preset - check the Scene pane.
