Is there a way to see the absolute coordinates of an object?
Is there a way to see the coordinates (X,Y,Z)  of objects so that I can more easily position objects next to it (for example, placing walls)
    Select the item and look in the Parameters or Posing pane.
  • OstadanOstadan Posts: 1,133
    Note, however, that if the item is parented, the coordinates are relative to the parent.
  • bitwelderbitwelder Posts: 212
    You can paste this into the Script IDE, and I believe it should give you world-space coordinates of your selected object whether or not it is parented:
    // get the object selected in your scene
    var oObj = Scene.getPrimarySelection();
    // print out the world space position in a message box
    MessageBox.information("World-Space Position for object '" + oObj.getLabel() + "': " + oObj.getWSPos(),"Info","OK" );
